SOUTHWEST MEET UP
Moderator: Event Co-ordinator
NVNL
Contact:
Re: SOUTHWEST MEET UP
Post by NVNL » Wed Feb 07, 2018 3:28 pm
Paul, thanks for letting me pick your brains on Sunday.
As it turns out my memory was accurate for once and the reg/rect output is 15.6v at the battery more or less throughout the rev range, rather than 14.5v as recommended here -
"Re: Charging issues
AWJD » 05 Aug 2017 1415
If you disconnect the 3 wires from the alternator, you should get a low resistance reading from each pair of wires. This would normally indicate that the alternator coils are basically sound. Unfortunately, the rectifier diode test only means that that part of the RR is ok - it doesn't mean the regulator output part is ok, unfortunately. If the alternator appears to be ok then the overall test for the RR is whether you get a voltage output of ~14.5V from the RR red/black wires when the engine is running. If not, it's likely the regulator has failed."
-so I guess I'll try the old Kwack one which Brickboy gave me.
Richard
All manner of things shall be well.
1960 LE Mark III
1964 Superdexta
1969 T100C
1981 T140ES
1993 MT350
#skippy1970
Post by #skippy1970 » Wed Feb 07, 2018 9:42 pm
Yeah give the regulator a try ,
just don’t let the smoke out :shock:
If my brain was to get any smarter it would become self aware and take over my body
MT350 GL36AA
NVNL
Contact:
Post by NVNL » Fri Mar 02, 2018 7:58 pm
Bike going well, but BRRRR!
Richard
1960 LE Mark III
1964 Superdexta
1969 T100C
1981 T140ES
1993 MT350
#skippy1970
Post by #skippy1970 » Thu Jul 04, 2019 6:33 pm
4th August Sunday
Due to popular demand a meet up will be on this date at “Louis tea rooms”
Kit Hill Callington cornwall PL17 8AX
As usual there will be plenty of classic bikes there as it’s the VMCC monthly meet also
Just turn up anytime in the morning or afternoon
Plenty of Tea and plenty of Cake or even a Fried Breakfast
Some fantastic roads to and from here
A great way to enjoy a bit of Cornish Sunshine :D
MT350 GL36AA
Post by lardmarc » Fri Jul 05, 2019 3:06 pm
Due to popular demand.
It's about time we got this going again. It only stopped because Jannersbee worked every Sunday, bollocks to him we're doing it. :shock:
My bike should be OK going over the border into Cornwall as it's virtually the same place according to everyone living North of Bristol.
#skippy1970
Post by #skippy1970 » Fri Jul 05, 2019 6:08 pm
jannersbee you need to stop working so hard and get your ass over the wrong side of the Tamar :D
See you Sunday :)
MT350 GL36AA
